Brake pedal kick back!? and Clutch pedal
  Fiesta Mk8 ST-3
Recently when your braking there is click/vibration off the pedal it's hard to describe. It does it even in wet and dry surfaces quit allot too.
On the clutch pedal there is a clicking when you lift off the pedal pretty much all the time. Been told that he greased the gear linkage and it's still clicking. Is it just a case of greasing/WD40 on the clutch pedal arm?
Any advice appreciated
  Mk3 clio 1.5
yeah as said this will be a problem with your abs, sometimes the sensor get clogged with mug aswell and this can affect the braking.
