Brake pipe repair kits
Stuiemc
  Audi RS3, Clio 172
Need to make up a pipe to loop my steering rack. Looking at this kit on eBay as I'd rather buy something to do it myself.
Just wondering has anyone got any experience of using a kit like this?
Mertin
  Ph1 172&Ph2 172 Cup
Surely the pipe needed will be much larger than a brake pipe fitting, more like 1/2” fittings for the steering rack? Wouldnt think that kit would be any use
  Clio 172 Cup
If its for looping and doing epas it'll be fine. I did it the other day with a similar kit. Need a pipe cutter if there is one with it.
Stuiemc
  Audi RS3, Clio 172
The fittings in the steering rack that need looped are M12x1mm so I've ordered brake pipe fittings for 3/16" pipe. The holes your talking about get plugged.
Ah brilliant mate I ended up ordering it so should get it within the next couple days. It includes a pipe cutter.
BashRacing
Remove the piston from the rack then you won’t need to loop it, just block off the ports, this is the micras one
  172
On a side note, if you’re thinking of doing smaller stuff that style of kit is absolutely crap. Especially from the likes of sealey, laser, amtech etc all the same rebranded soft metal that can barely grip copper lines let alone OEM steel lines and wears out very quickly leading to dodgy wonky flares that f**k the threads on the unions in no time.
Stuiemc
  Audi RS3, Clio 172
Had to pop to a mates garage so got him to knock me a pipe up whilst I was there. All sorted now thanks. That does look like a better solution if I was removing the rack but looping will do the trick.
