Brake position sensor
Car  Renault Clio 172
Howdy guys!
This may seem like a really silly question, but how do I go about adjusting the Brake Position Sensor?
Thanks in advance!
Is this the brake pedal switch?
If so you just push pedal down, look underneath it and twist the plastic connector out. You then pull the plastic plunger out all the way, and stick it back in and press on the brake pedal and it'll adjust itself.
Sent from my SM-G928F using Tapatalk
All sorted now dude, cheers for the help! I didn't want to pull it too hard cause I have a tendency to break stuff 😂
