brake servo prob
Car  2001 clio rsi 1.6 16v
i have just had manifold fixed now brake pedal is hard like servo not working any usual causes? help apreciated, looked at vac pipe seems ok guy who did my manifold recons needs new servo seems like a coincidence,
please help
Servo vac pipe may be fitted but somtimes they are loose if they have been pulled out
fit a cable tie to it TIGHT! as a quick fix, see if that works! If it does then replace it with a small jubilee!
Second thing to check would be at the servo end
thanks will try that, am i right in thinking vac pipe is one atached to inlet manifold??
anyone in northeast area willing to look at in 4 me??
not that i know of fitted well had it to another garage and in 5 min they told me i need new servo but im not convinced as they just took it for a drive a need sum place that wont take the mick, when braking a can here a very slight gurgling sound under bonnet?
im going mad any ideas what this mite be any way i can test servo ect? heard of something call vac control valve mite this be prob? please help
engine off pump the brake pedal until it goes hard hold it down then start the car if it goes down a bit the servo is working if not it's faulty or it might be the one way valve faulty if it has one
ginna took the words right out of my mouth,did the pedal go down after you pumped it then turned the engine over?
