Sam I've read lots of your posts on here and you know what your talking about, but there is no way I'm accepting there is no benefit to be had
Im sorry but that's just not correct, decent pads will have a higher upper working limit however Any pad has its limit and when you reach it fade will happen
grooves will help disperse the gas regardless of which pad you choose, wether it'll be noticeable on a light car like the Clio is a completely different argument but for £30 extra per set of disks I don't see why you wouldn't want them
That's the key, it's going to be more of an issue in heavier faster cars, but that wasn't the argument my cup is only 210bhp but I've experienced fade with 2500's and 1155's
As soon as I feel any difference then I come in. I am not in a race car, it is a road car with occassional track trips.
People confuse road cars with full blown race cars. Because Road Car.And.
I do now.Did you know race car says the same forwards as backwards.
Motorsport collage taught you something then.
I do an engineering degree at uni you nonce.
The holes will crack IIRC.
grooved discs don't last as long, simples, a bit of gas vs 300psi+ of pad force, pad wins
Brembo max discs eat pads with no added benefit to breaking performance.
I think the above is the answer.
There are " 2 " aboves , lol . At the end of the day it's down to personal preference . Like i said , i'm more than happy with my set up so it's what i would recommend if somebody asks . Someone running HC's with DS2500'S might be happy with theirs and recommend that setup . Each to their own . As long as my car stops when i press the middle pedal thats all i care about . And if the discs cost a few quid more , so bit it . I'm quite happy to shell out that extra few quid . I don't think there'll ever be a conclusive answer to the " best setup " .
Just finished mine, where are you doing yours?I do an engineering degree at uni you nonce.
