Brakelights Stuck on!!
Disconnect it, see if its still sticking on, if it is, its the wiring, if its not, its the switch.
Then you can ask renault / partco for prices on the switch, then garages how much to fit it.
Never done it myself sorry, why dont you take a look, and see what you think, unless your not technically minded.
You may have accidently disconnected the wiring which sits above your feet near the pedals. It's easy to do, I did this with my clumsy feet, popped down to renault and the guy had a quick look and reconnected it in about 5 seconds. Have a look and see if you can spot any loose/broken connections.
Hope this helps
