I think he means the abs rings ?? If your new discs don't come with the abs rings you'll have to remove them from your old discs and put them on your new discs . Heat them up to remove them .
no havent bought them yet.......
i know they can b quite expensive all in.....
anyone know where i can get a set from (rear's). without it hurting my pocket.... if not i just have 2 make do with just the pads... wats ur advise on decent, inexpensive rear pads. which one's?
cheers gud man......
its just tat iv got alot of things 2 change....
im doing 60k service + cambelt replacement and brakes...
tryin 2 on top of thigs, makin sure i do all necessary stuff and not forget anything...
wat u reckon? do u think iv left anything out:
1. front disc's + pads
2. rear pads
3. cambelt kit.
4. aux belt
5. oil filter
6. fuel filter
7. spark plugs
8. oil.
also is there any particular brands 2 go 4 in regards 2... oil...spark plugs..... etc....
cool...... rule tat 1 out then......
also my stop and handbrake lights flash on and off alot of the time....
also i just did the quick diagnostic check... came up with fault "t" and "h".... something 2 do with ignition and oil sensor respectively
Your stop and handbrake light is probably worn pads , causing low level brake fluid .
" t " means an injection fault and " h " is like you say , oil level sensor fault . You can reset them with the button for resetting your trip computer .
