brakes squeaking
  clio1.4 dynamique+ 01 Ph2
I was wondering what would cause breaks to squeak!
they only squeak when you brake light, they do not do it when braking hard, if you do a emergency stop and get the brakes hot they stop squeaking for a wile, then come back but not as loud. any ideas?
  BMW M3
Prob just need some copper grease. Its quite normal for a squeak to happen at light braking and not full.
I had my pads out the other day and forgot to put some copper grease on the passenger side and am now regretting it lol...
  AMV8, Mk1 Golf
my back one squeek drives me carzy but cant do anything about it as they are on drums at the rear
  Tweaked Leon Cupra R
Take the pads out and clean the carrier/saddle wi a wire brush to remove any build up on brake dust.. Copper grease and put back it! Should sort them.!
p.s. dont put the copper grease near the discs or the front of the pads! Or you wont stop anymore!
Thanks will give it a try, dose any one know if there is any walktroughs on how to change the front and back breaks on the clio mk2 ph2
thanks
thanks
Its just like the guide on the forum for the 172 brakes.
There will be a guide soon when i fet down to finishing it.
Its very easy though.
