i am looking for a good road setup for a 1.2 16v as i mainly drive on country roads and lans, it appears that brembo max discs and some mintex pads are a fauvoured option, can any1 suggest a fullsetup, looking to spend around £100, cheers.
Stock disks (£50~60 from Halfords or other parts places) and stock FDB 845 pads (£17.99 at Halfords) and bleed the brake fluid with some decinet dot 4 stuff.
Nope I'm meaning to write one but its quite simple.
Get a oneperson Gunson eazy bleed kit from Halford etc for £17 or so and follow the instructions.
You just fill it with fluid and attched it to both the fluid reservoir and a car tyre with max 12psi in (I've got a load of spare wheels so its no a problem)
Then just open a bleed nipple with a pipe attched and let the fluid run out you'll see air bubbles and after a 20 seconds of seeing nice constant flow close the bleed nipple back up replace the rubber cover cap and do the next wheel.
the stock setup i have now is ok, vented discs, but i have been in other 1.2 16v with mintex uprated brakes and the stopping distance is a lot shorter than mine
