Braking Problem
Car  Skoda Fabia vRS
right, this problem has been there for a bit now
at any speed after approx 50mph my car will pull to the right when i brake, it gets worse with speed
it happened when i had my 1.4 brakes, it happened after the system was bled and new brake hoses, its still happenin with new calipers discs an pads (16v setup)
my tyre pressures are exactly equal an i check em every week so its definitely not that, and im almost certain there balanced correctly as it aint long since that i had em done
any ideas ?
one of your wheels may be buckled BRUN, tracking, camber there are loads of things it could be. worse case scenario(seeing as you say it has always done it) is that it was in a crash before you had it?
dont think its the wheels as ive swapped em around and the problem hasnt moved
had the car HPI checked an no accidents came up, and everythin looks in order
yea im usin wider than normal wheels but it never really depends on the road, its always to the right
im pretty sure its somethin brake related as i was on this steep hill the other day at some lights, put the handbrake on, and i noticed that the dash went unlevel, like one side was brakin an one side wasnt, the left side didnt really do anythin, but the right did what you would expect when u put the handbrake on, on a steep hill
other than that could it possible be steering related ?......like the rack ?
How about a fault in the brake master cylinder / servo since thats the device that applies pressure and distributes the fluid through the system. Could be a scored barrel or faulty seals? I presume you are not loosing any brake fluid?
Your last post makes me think it is rear brake related where the drivers side rear is working the best, slewing the car to the right at higher speeds?
Other possibility could be rear brake limiter/compensator?
You say you have a 16v setup. Is this with discs all round? If you have converted to discs all round you must use the correct master cylinder as a larger fluid displacement is required?
Neil
cheers Neil, no ive only got 16v brakes up front, the back is standard 1.4 drums
hmmmm
OK, probably the first thing to check (if you havent already) is the rear brake cylinders and drum/shoe adjustment on the rear. Perhaps the passenger rear is part or completely seized? Also check the handbrake cable and mechanism is free and working as this is integrated in the mechanics of the rear brakes also.
Neil
Could it be something as simple as weight distrabution?
ie is there more wieght on the drivers side (odviosly, but apart from the driver have you got anything else heavy on that side)?
Paul
Strange, no idea then. My car seemed to be pulling to the left while braking a while back. Quite dramatically as well. But it only did it towards the end of the braking, ie within the last few feet. I found out what it was though. My new wheels, they were just following the road down towards the kerb. Serves me right for having so much grip and wider wheels. Got used to it now, actually helps me round corners sometimes.
Paul
If it pulls to one side under braking it is 100% a problem with your brakes... most likely the front ones as they do most of the work.
I had the same thing with my old car.. the rubber seal around the piston on the brake caliper was knackered so over time water got into the piston and it started to stick with all the crap that had gotten in.
This meant that the piston wasnt travelling smoothly and hey presto poor braking effciency leading to it pulling to one side under braking.
You say it pulls to the right when braking therefore you left brake has the problem... the right hand one is working much better so that is why it pulls you towards the right as this wheel is slowing down a lot quicker than the knackered left one.
Take you wheel off and have a look at the caliper on the front left hand side.. any sign of a shagged seal and you have found your culprit.
sounds like its the rears that your having problems with, as you have changed the fronts.
Go to a local garage and ask the to do a brake test, this should highlight any problems with the brakes
Clutching at straws now ..... if its not brakes it can only be related to suspension, ie. different springs either side on front, worn bushes or problems with torsion bars at the rear? But surely if it was this the car would handle like a dog in heat!
Neil
the suspension is not even 1 year old an is Bilstein......fitted by Nick at Hill Power.....who also adjusted my torsion bar
i would like to be able to get a free proper brake check at a garage but i just know there gonna try an get me to get new rears without even checkin the car properly......just to make some money
hmmmm what to do....
do you think it would be the best idea to get the trackin/geometry all sorted first......just to make sure its spot on
Checked mine today BRUN, and there fine on a flat road. Just heads to the side of the slope of the road, usually the left as we drive on that side on the roads curve down to the pavement.
But you say urs pulls to right? Hummm!
