sorry to sound stupidAdam K said:you won't see a physical speed increase instantly when you plug into the master socket, i just want to know the sync speed.
it will take 3 days for your speed to rise again.
.Griff. said:Your downstream Attenuation is fairly (verging on very) high which would suggest a long physical line length and/or a noisy line and the SNR is just above the threshold to remain connected
wxmlad said:when you say noisy line, what does that mean??
so should my next step be trying to get BT do look in to it? ive been in and out of msn messenger like a bloody yoyo tonight!.Griff. said:Attenuation is still relatively poor (i.e hasn't improved while not the cause of any problems) and SNR is only higher (better) due to the lower sync rate so as a result I think we can safely say that extensions/extension leads aren't the problem.
.Griff. said:Probably the best thing to do. MTU can cause problems with MSN messenger and other apps but (and no offense) I think that's a bit complicated for your average user to mess with.
