braodband slower than dial up - help!
Adam K said:
you won't see a physical speed increase instantly when you plug into the master socket, i just want to know the sync speed.
it will take 3 days for your speed to rise again.
sorry to sound stupid:o do i just do the speed test again?
at master socket!
The speed test has completed on test server speedtester1.nat.bt.com for user 01490....... and you have downloaded a 1.7Mb file at a speed of
/images/icodownl.gif 294 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is 81..........., your browser is reported as being Microsoft Internet Explorer 6.0 and is running on Windows XP.
YESTERDAYS TEST!
The speed test has completed on test server speedtester1.nat.bt.com for user................. and you have downloaded a 1.7Mb file at a speed of
45 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is .............., your browser is reported as being Microsoft Internet Explorer 6.0 and is running on Windows XP.
.Griff. said:
Your downstream Attenuation is fairly (verging on very) high which would suggest a long physical line length and/or a noisy line and the SNR is just above the threshold to remain connected
when you say noisy line, what does that mean??
Background noise that would affect the signal. Poor joints, bad connection in the street cabinet, aluminium spliced into the line etc..
Re: broadband slower than dial up - help!
i cant ive got to wait now
/images/retest.gif
You have already performed a test within the last 30 minutes. Please come back later and retry your test. Constant attempts to retest will be logged by the system and may be reported to your ISP. You may next perform a test on Tue Jul 25 21:32:16 2006
The speed test has completed on test server speedtester1.nat.bt.com for user 01 and you have downloaded a 1.7Mb file at a speed of
/images/icodownl.gif 53 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is 81., your browser is reported as being Microsoft Internet Explorer 6.0 and is running on Windows XP.
this always happens , im going along fine.. then i get logged out of msn, if im listening to the radio goes off and i get p'age cant be displayed' and its goes slow all nite:mad::S
Ill do another test in a bit and see what it says
The speed test has completed on test server speedtester1.nat.bt.com for user 014 and you have downloaded a 1.7Mb file at a speed of
333 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
Your IP address is 81., your browser is reported as being Mozilla 5.0 and is running on Windows XP.
you still haven't given us your line stats when plugged into the master socket.
as i mentioned before, even if you do sync higher, you will have to wait 3 days of solid sync at that rate for the BRAS to update.
DSL Connection
/images/bull__md.gif Link Information
Uptime: 0 days, 0:04:16
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,792
Data Transferred (Sent/Received) [KB/MB]: 334.00 / 1.39
Output Power (Up/Down) [dBm]: 11.5 / 16.5
Line Attenuation (Up/Down) [dB]: 31.0 / 52.0
SN Margin (Up/Down) [dB]: 22.0 / 15.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 668 / 0
FEC Errors (Up/Down): 0 / 2 CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Attenuation is still relatively poor (i.e hasn't improved while not the cause of any problems) and SNR is only higher (better) due to the lower sync rate so as a result I think we can safely say that extensions/extension leads aren't the problem.
so should my next step be trying to get BT do look in to it? ive been in and out of msn messenger like a bloody yoyo tonight!
Probably the best thing to do. MTU can cause problems with MSN messenger and other apps but (and no offense) I think that's a bit complicated for your average user to mess with.
prob it took me 24 hours to find out the line stats lol:o
