Flam686 Car Clio 172 Ph1 Mar 10, 2018 #1 if I wanted to change my front discs, would re-using the long studs be ok. IE to press them out and back into the new discs ?
Djw John Scotland - South ClioSport Area Rep Car Not a clio :( Mar 10, 2018 #2 The front studs go into the hubs not the discs, that's the rears.
Louis I Love Ed Sheeran ClioSport Club Member Car BG 182 Mar 10, 2018 #4 You can reuse the studs just fine if you do remove them from the hubs. Bit of heat to break the threadlock and double nut them off
