Brembo HC Disc defect?
Hey,
I had my discs fitted at Fred's just over a year ago, and I've noticed a few days ago the drivers front disc has a 5-10p pence size of the surface just completely disappeared, it goes back ~2-3mm - is this a defect?
Also, what sort of warranty do the Brembo discs cover?
I'll get some pics up tonight!
Pretty sure this isn't normal?
  Mk1 MX-5 (x3), Westy
Pic would be good - mine did have a dimple a few mm deep (wear marker, I presume) but it was only about 6-8mm across.
Hmm ok!
Well I'll get some pics up ~6 ish and then we can determine if it's normal, I wouldn't have said so though as when I was quickly looking I only saw it on one disc (unless the other one was behind the caliper at that moment).
koi
It will be the wear indicators, if you can't see any time for new discs.
  Inferno 182 & Saxo
always worth keeping an eye on them every so often - OP how many miles did your set do and under what conditions?
