Broken cat
Car  clio sport 172
hello, my cat got broken when i scraped it last night, so i got a decat pipe that i will use instead.
my question - i made a remap with the cat, so will there be any problems...for example with the lean-rich fuel mixture or something else due the decat pipe being there instead the cat?
is it necessary to make a new remap or not?
thnx!
ok thanks, so no posibillity of burned exhaust valves due too-open exhaust (decat-straight through) + remap?
I certainly wouldn't say so, however someone else should be able to confirm 100%. What other mods do you have ?
Do you have the facility to remap ?
it's a stock engine with a straight through 63,5mm gr.a exhaust + a remap (it gives much more fuel in low-mid revs so it has much better torque from start)
