Bucket seats quick Q
Sourced some Cobra bucket seats, just cheapy ones as I'm not serious about racing or any of that!
But anyway I'm new to all this can someone please explain what ill need to mount them? Or just poke a hyperlink @ me.
Iassume Ill need a subframe?? (Is this the thing with the runner on?)
I think if I'm right in thinking what a mount is,that it already has mounts on the seat for attaching to a subframe.
I'm a bit lost as you can see any help appreciated
Thanks!
The seats in question are Cobra Clubmans, not sure if this makes any difference or whether the subframes are model dependent.
Subframes are available from the likes of demon tweeks etc, 2modified, don't forget your CS discount if you go down this route.
No idea how to fit them or harnesses!
Hopefully someone else will be along in a minute!
They also do Cobra extra low sub frames which may be worth looking into seeing as your such a lanky streak of piss!
Cheeky f**k im only 6ft1!!
You wish your c**k was as lanky as mine though ;) haha
Anyweay yeah I dont have a problem fitting bits I just need to know what bits to buy!!
ta muchly :)
Alex has pretty much answered your question you need to buy x2 frames approx 75-100 pounds each mount these to the seats (cobra can supply screws if you havent got any) but there nothing special - then just buy some x8 cap 12.9 bolts m8 using the existing nuts Job done (dont forget to disconnect the battery and read the guide on http://www.cliomods.com/styling/fittingrecaros/ should help you! :)
Paul you studmuffin many thanks for replying :)
Bolts not a problem I know a bolt man as so to speak ;)
