Built In Freeview not Working
Coby.
Car  XC60-R.......V40-R
Just Setup my 37LG6000 which has Built In Freeview but I'm getting nothing :(
Done a Check on Freeview.co.uk and I should be receiving some BUT not all of them however I'm getting none :(
Reading another thread it has been advised on checking my Antenna Cables etc. I know we have 2 Aerials but both are oldish and I just ly's in the loft and I run a fairly long cable from it to my room,
Should I buy a Booster and see if it helps?
Andy.
You have a freeview aerial? I'm pretty sure the freeview aerial is different to a standard one and needs to be pointed at your nearest freeview broadcast tower.
Yeah I'm thinking I need a Digital Aerial don't I?
I'll go buy one and try it again.
I've just bought a Digital Amplifier and tried that BUT It has picked up a couple of the Channels but the Signal is pretty broken... The Cable between the Amplifier and my TV is a pretty old tired piece which I just found in the garage,
Would I be better buying some New TV Aerial Cable and trying again?
Digital aerial? We have a bog standard old one in the loft from the 80's and it picks up Freeview fine.
Ok I now have Freeview :)
I went into the Loft and Checked over my Aerial Connections and we are running a few splitters so I reworked them and put my Aerial as Primary from the 1st Splitter and let the TV Re-Programme and now have all the Channels I believe and the Pic is pretty good to say the least :D
