cable in passenger seat???
Car  clio mk2
what is the cable for in the passenger seat, i think it is the airbag but i dont want to cut it in case it is needed. im trying to change the seats to ones from a suburu wrx. can n a 1 tell me wot this cable is 4.
thanx
certainly wouldnt just cut through it... could be pricey to repair.
whoops. ive already cut through it. i figured i cld join it if it was important. but now when i turn on the car my serv light cums on and so does a wee light in the shape of a seat with sum 1 in it and a circle. on the left hand side.
wot does that mean??
Is it wire, if so solder it up or just use an electrical connector. People say you need to re-set the thing at Renault etc, bulldust. If it's an electrical wire just solder it.
oh dear... :dapprove: Gonna be a trip to renault too once repaired to get the warning lights cancelled. Really shouldn't just go cutting through cables in a car if you've no idea what they're for :rolleyes:
Whilst the warning lights are lit all air bags are deactivated and your pre-tensioners will not work. Lets just hope you haven't knackered anything to do with the airbag computer or them scoob seats are gonna set you back a pretty penny!
Bulldust - Once they're all connected up the warning lights on the dash go out (did on my 2001 172 anyway)...
Get the soldering iron out
bulldust? :S
Did you cut your wires or simply unplug them?
Ah well either way, lets hope they do...
