Hi all!
Few weeks ago i found leaking bolt on camcover (see pic below) so today i finnaly got myself to fix it, got some degreaser, torque wrench and loctite sealant (glue for bolts)… hope i fixed id, will se tomorow when i'll go for a drive (it says on loctite bottle that the sealant should be fully dry after 12hrs)
Well the reason i'm writing this is that i found some oil in one spark plug hole (see pic below). This is the closest hole of all 4 to the leaking bolt (you can see the leaking bolt on the bottom of picture, its just resealed and cleaned, so thats why there's no oil to see around it).
So my question is, is this oil here because it somehow dripped from the leaking bolt, or i have a leaking cam cover (sealant)? Or anything totally different?
Car is 172 ph2, runs great, doesn't use oil (it uses a little but i don't need to top it up between regular oil changes).
Any help appreciated
Sorry for my crappy english
