cam/timing belt failure ????????????
  rsi 1.8
i have a clio 2.0 16v sport 2001
with a snaped cam belt, what damage is caused by this????????
Da
  Less
New engine is often easier and more cost-effective than repair.
All depends on the damage done.
CrippsCorner
  208 GTi
Taken from the thread below this one...
only available from renault £3340+vat NEW
or £3k for a service exchange unit
all manufactures have to be able to supply parts for 10years after final date of manufacture
  106 GTI
Surely though if your looking for replacement engines its easier and cheaper just to fix the original.
The original needs to be removed if being replaced so why not repair?
You will then also no that the cambelt and auxbelt is new
I got my 182 engine for £250 quid cost about 60 to get it shipped down here though so £310 all in. Then fitting unless your doing it yourself?
  GDI Demo 182, Rsi Spider
repair is usually
belt kit
valves (usually 8)
head set
labour wise
- Total head overhaul
- Piston crown clean up
- refit
circa £1200-£1800 dependent on damage inc labour etc
  Phase 2 172 Cup
my rebuild cost 1300 basically
that was 16 new valves
valve guides reground and seats done
head gasket
water pump
timing belt and aux belt done
  Ph1 track 172
head gasket
water pump
i had 4 new valves,
and didnt have the valves reground,
all new gaskets and stem seals,
water pump
timing belt and tensioner
cost £180
was the extent of my rebuild
everyone seems to think itsa million pound job every time,
worth havin a look at repairin it, cz if ur lucky,
it cud be like mine £180 n its better than it was before
