Camber bolts question...
dzm
Car  Inferno 182 + cup packs
I'm Thinking of doing the cheap camber bolts option of fitting 12mm bolts in the top eyelet to get -2 degrees camber. I understand that ISO 12.9 should be strong enough grade for the bolts.
I'm guessing the nuts should be 12.9 as well, or will 10.9 be sufficient?
Should I use Nylock nuts?
I will measure the length of the current bolts, but does anyone know how long they are off the top of their heads? Around 50mm?
