Camber Help and Advice
Car  clio dynamique 16v
Sorry if this is brutally obvious... but...
Does anyone know how easy it is to install camber shims?
Any step by step guides going?
Or even how much labour costs it would cost me roughly to get it done at a garage (or even how long it takes)?
Also, does anyone have any examples of 1 and 2 degrees?
Cheers!
Its simple, takes like 30 mins a side tops.
losen hub bolt
jack car up, put rear on stands and remove wheels
take off hub nut, then remove caliper
remove disc
then there will be 4 torx with nuts on the other side, remove them, fit camber shim fit it all back together.
losen hub bolt
remove disc
Haha okay, Im gonna give it a go in a couple weeks... ill let you know how well i do! Thanks bud! :)
