camber or standart bolts?
Car  clio 172
Hiya first sorry if there is a post already ,but I could not find it . I have a clio sport 172 mk2 standart , recently bought set of raceland coilovers ,but they came without camber bolts. So can I use my standart bolts or I need to purchase camber ? And if I have to buy them what is the size of the camber bolts and a good brand ,please?
Thank you in advance .
You can use the standard bolts. With the lower ride height the camber should be increased a bit from standard anyway.
Eibach do camber bolts for about £20, available from lots of places. If you don't drive the car on track then it's probably not worth fitting them though.
first thank you for your replay , they are raceland with elongated top hole ,so I don't think I need camber bolts .
