camber setup
fil_b
  172 FF and Fabia VRS
i got my car sorted now
koni shocks with eibach pros
had the tracking sorted do i running slightly toeing out - poss 5 degreese
atm whent hey checked camber was at 1.5 and 2 deg at the rear
what is a good camber setup for front and rear
thanks
feebs
depends what you use the car for, road use -ve 1.5 will be good.
unless you fit camber shims the rear cant be changed
fil_b
yeah i want to look at camber shims and bolts
mainly road use but want to do some track days also
you mean camber bolts for the front right? I run about -ve2.5 on my 182 at the front.
Im not 100% on what my rear is because I havnt checked it since I fitted the shims but I went for an extra 1 degree.
Hopefully going to get it all checked this week to find out where i stand.
Coby.
  XC60-R.......V40-R
Still waiting on my Camber Bolts and Shims :(
Could be another 2 Weeks as yet,
My car has not had the tracking done since I Lowered it a while ago so should I do the Tracking soon and wait for my Camer Kit or just wait and get it all done at once, It seems to run quite true, If I got it tracked now would I have to do it again once the Camber Bolts and Shims arrived?
just wait and get it done all at once,
problem iv had in the past is no one will touch my as soon as i say iv got camber bolts thats it. Not a problem now as I book it in a mark fish for set up's
the rear end wont matter, its either fixed as standard or fixed with the shims theres nothing else that can be done by a garage. What shims have you got on order?
fil_b
i want to sort the camber on the front and rear
just what ever the shocks and springs give it atm so want to aline everything so its all true
so you think should camber the front more than the rear??
Coby.
  XC60-R.......V40-R
I've ordered Whiteline Camber Bolts and Shims... Pretty sure I know a place that will Fit them and Set the Camber Up for me :D
