182 trackday racer
Before putting the cams in RStuner records 100% Injection Duty Cycle if I pull the car over 7100rpm... Some argue that that figure may not be correct! But I have also used some methods of calculating the IDC and they have all shown that ~200hp would be on the edge for the stock injectors. However I’m really feeling bad about it. Don’t want the car to ever have the chance of running lean. As stock injectors are rated by MM at a max IDC of 90% and I’d rather not exceed that.
Since I’m mounting cams in the car and it will be remapped by Henk would it be any good upgrading to the 283cc IWP042 injectors to the bigger IWP043 injectors at the same time?
I shall say that the car goes 7000km (4000+ miles) on track each year so it’s got a pretty hard life. And I do some ice racing with the car during the wintertime, it may be as cold as -30 degrees so I need propper headroom for the injectors. So I’d like to keep within those 90% IDC to be on the safe side. The cost of new injectors does not really matter; just want reliability to be as high as possible.
Happy for some response!
