XC90, 330d, Trophy’s
Hopefully a different camshaft question...
i know there are the usual 421's, 428's and 438's etc, along with some now using the 197 profiles, but is there anything out there a bit more lairy, namely for a high compression engine that's purely for track use?
im happy to consider solid lifters if required, along with a lairy camshaft profile if the rev limit can accommodate going higher to suit.
but what else is out there, what has been tried and tested and given proven good results?
or is it a case of sticking to what's mentioned above even with high compression?
cheers.
cheers.
