can some one match these up for me...
  1.8 RSi MK1 Superchipped
need to knwo which wires do what...
previos owner of my RSi was a bright one and cut off the connector block for the head unit. The wires I have to play with are as follows...
Black + Grey
Green + Yellow
Grey + Red
Grey + Blue
Green + Black
Beige
Beige
Mouve
Mouve
Pink
Pink
White
White
total=13 wires....
according to the haynes manual, comming from the head unit I should have...
Mouve + White - LH rear Speaker
Beige - LH rear Speaker
Orange + Blue - RH rear Speaker
Beige + Red - RH rear Speaker
Black - Earth
Red - fuse box then ignition
Yellow - fuse box then instrament panel
Pink - RH front Speaker
White - RH front Speaker
Brown - LH front Speaker
Green - LH front Speaker
total=11 wires
anyone done this before and know which wires to connedt to each other?
help much apriceated! thanks fellas!
  silver valver/hybrid
found this on another furum might be of some help
""The best thing to do is grab a test light and do the following:
Attach the wire from the test light to a good clean earth on the cars body and prod the wires, when one lights it - bingo, the perminant live.
Now turn the key in the ignition and do the same, when a differnt wire lights, you have found the switched live.
Now turn on the headlights and do the same again, when it lights you have found the illumination wire.
Now unclip the test light and attach it to the perm live wire. now prod the other wires, when it lights you have found the earth wire.
Now all you have to do is find the speakers, to do this grab a 1.5 volt battery and hold one of the wires on the positive, now touch all of the remaining wires (one at a time) unti you hear the speaker "pop", you have found a pair of speaker wires.
Carry on doing this with the other wires until you have found them all - plug in the arial and job done!!""
Same when i got my 16v - if you go and buy an ISO lead from halfords it labels the wires and most of these are the same colour etc as the ones in the car - for those that arent you can usually trace them to the individual speakers but the power ones are obvious...
