can someone pick me the best brake package
there are fast road pads on there, EBC green, Mintex extreme etc etc
where are you based out of interest, as you can collect if local
london mate,
hince reason i chose gsf, closest to me and people been rating the gsf disc's and pads, but cant find the ones people are rating.
FredYozzasport said:
hum fair enough, if you get stuck, let me know!
im stuck! could u pick me something from that gsf website that would be as good as standard set-up if not better ..please :D
This does the trick most of the time.
Or go for different pads,with standard discs, i recommend ferodo ds2500
go in and ask for Brembo discs, EBC green or Mintex extreme pads
fred arnt those for heavy track day( EBC green or Mintex extreme pads) reason i ask is cos i heard if its for track day in normal driving conditions it would sqeak when braking.
thanks for the help so far fella.
those pads last about 5min on a track day, they're a fast road pad at best
i just fancy ones that dont sqeak but better then standard. heard the milteck sqeak when used abit hard may go for the green
cheers for the help guys
i got some ds2500's and some brembo pads from yozza and the stopping is loads better... there is some new squeaking though which is annoying...
Have put some copper grease which helped but the squeak is still there...
anything that can be done?
