Can you run throttle body's on your standard ECU
  Clio sport 182
I want to fit throttle body's but I don't know if you can use your standard ECU, need help please?
  182/RS2/ Turbo/Mk1
Possbile, but not ideal. You need to take a MAP signal from after the throttle plates, which means tieing them all together and playing around with pipe sizes etc.
Easiest on a ph1 (cable throttle), but possible on all.
Is there a reason you want to spend a load of time/money doing so rather than just take the easy (and realistically cheaper in most cases) option and go aftermarket though?
  Clio sport 182
Well I was watching the ktec step by step videos on YouTube and I'm sure they just put the laptop into the standard ECU.
And they changed it to a throttle cable to which comes with the kit.
And all the old plugs and thing like that went back into the throttle body's.
Any of you seen them videos ?
  182/RS2/ Turbo/Mk1
They plug in a new ecu which is programmable.
  HBT 172 Cup
Plugged into GEN90 ECU.
EDIT: Seems im a bit late lol
