Pictures sent by Multimedia just stay in my outbox and the phone tells me it will resend in 10 minutes or so. I checked on Nokia's site and they referred me to Orange (my network). I contacted them and they sent a long e-mail of instructions to follow. I did this but still it won't work!! This is what was sent...
Dear Mr Harris
Thank you for your email regarding your Nokia N95 phone.
I am sorry that you are experiencing problems accessing wap on your phone and apologise for any inconvenience caused.
May I recommend that you check the following settings on your phone and this may resolve the issue for you:-
press menu
select settings
select connection
select access points
select Orange GPRS WAP
(if a customer does not have any preset access points then within 'access points' >>> press options >>> select 'new access points' >>> select 'use default settings' >>> select connection name >>> input 'Orange GPRS WAP' (customers choice) >>> press ok)
GPRS WAP data settings
select data bearer >>> ensure packet data is selected >>> press ok
select access point name
input orangewap (case sensitive) >>> press ok
select username >>> ensure this is left blank >>> press ok (Shows as none)
select prompt password >>> ensure no is selected
select password >>> ensure this is left blank >>> press ok
select authentication >>> ensure normal is selected
select homepage >>> input http://orangeworld.co.uk/ (case sensitive) >>> press ok
press options >>> select advanced settings
select network type >>> ensure IPv4 is selected
select phone IP address >>> input 0.0.0.0 >>> press ok (shows as automatic)
select DNS address >>> input 0.0.0.0 in both fields >>> press ok (shows as automatic)
select proxy server address >>> input 192.168.071.035 >>> press ok
select proxy port number >>> input 8080 >>> press ok
return to main screen
accessing Orange World
press menu
select web
press options >>> select settings >>> select general
select access point >>> select Orange GPRS WAP
press back
press menu
select settings
select connection
select Orange MMS
(if a customer does not have any preset access points, within 'access points' >>> press options >>> select new access point >>> select use default settings >>> select connection name >>> input Orange MMS (customers choice) >>> press ok)
MMS data settings
select data bearer >>> ensure 'packet data' is selected >>> press ok
select access point name >>> input orangemms (case sensitive) >>> press ok
select username >>> input Orange >>> press ok (shows as none)
select password >>> input Multimedia (case sensitive) >>> press ok
select homepage >>> input http://mms.orange.co.uk (case sensitive) >>> press ok
select proxy server address >>> input 192.168.224.010 >>> press ok
MMS setup
press menu
select messaging >>> press options
select settings >>> select multimedia message
select image size >>> select small >>> press ok
Any idea's what l can try without having to call them up?
Dear Mr Harris
press menu
select settings
select connection
press menu
select web
press back
press menu
select settings
select connection
select Orange MMS
MMS data settings
MMS setup
press menu
