Canon 700D Setup. Whats Wrong?
eugegall
Evening,
Current us a Nikon J1 for work and its a very good, simple point and shoot. In auto its brilliant but the lens wasn't wide enough.
Just bought a Canon 700D with a 10-18mm wide angle lens.
Every time I take a photo in auto the whole image is really dark. Even if the room is bright it darkens the image massively, which hides the detail.
Am I being stupid and doing something wrong?
I am no way an expert so any pointers would really help.
.Joe
Evening,
Would you be able to upload a test image to Flikr so we can see settings etc?
.Joe
EXIF — this group of metadata is encoded in 22,732 bytes (22.2k)
Make Canon
Camera Model Name Canon EOS 700D
Orientation Horizontal (normal)
Modify Date 2015:08:26 13:23:16
2 days, 34 minutes, 35 seconds ago
Artist
Y Cb Cr Positioning Co-sited
Copyright
Exif Image Size 5,184 × 3,456
Exposure Program Program AE
Sensitivity Type Recommended Exposure Index
Recommended Exposure Index 200
Exif Version 0230
Date/Time Original 2015:08:26 13:23:16
Create Date 2015:08:26 13:23:16
Components Configuration Y, Cb, Cr, -
Shutter Speed Value 1/32
Aperture Value 4.97
Exposure Compensation 0
Metering Mode Multi-segment
Flash No Flash
Focal Length 10.0 mm
F Number 5.00
Exposure Time 1/30
Owner Name
Lens Model EF-S10-18mm f/4.5-5.6 IS STM
Color Space sRGB
Lens Serial Number 0000034729
Maker Note Canon (7,840 bytes binary data)
User Comment
Sub Sec Time 03
Sub Sec Time Original 03
Sub Sec Time Digitized 03
Flashpix Version 0100
Interoperability Index R98 - DCF basic file (sRGB)
Interoperability Version 0100
Focal Plane X Resolution 5798.657718
Focal Plane Y Resolution 5788.944724
Focal Plane Resolution Unit inches
Custom Rendered Normal
Exposure Mode Auto
White Balance Auto
Scene Capture Type Standard
Serial Number 298075019432
Lens Info 10-18mm f/0
GPS Version ID 2.3.0.0
Compression JPEG (old-style)
ISO 200
Resolution 72 pixels/inch
Thumbnail Length 11,581
Heres exif data
Geddes
  Fiesta Mk8 ST-3
Make Canon
Artist
Copyright
Exif Version 0230
Aperture Value 4.97
Flash No Flash
F Number 5.00
Exposure Time 1/30
Owner Name
Color Space sRGB
User Comment
Sub Sec Time 03
Exposure Mode Auto
White Balance Auto
ISO 200
Heres exif data
the Aperture Value seems quit high at 4.97, other than that i can't see anything wrong. Could be the Expossure Compensation. make sure it's set at 0 , could be set to make the image darker than what it is
Aaron..
Everything looks alright I think from the exif.
You haven't got a filter on there have you @eugegall? That could throw things off.
Did you buy new or second hand?
Shoot using AV at 10mm f/4. Then TV at 1/125th. Make sure iso is on auto. Then try each of the scene modes and full auto.
All on the same subject in daylight. Things should be adjusted automatically to suit.
