Can't bolt wheels back up after coilovers......spacers?
Chris205
Car  Many Things
Hi guys,
I've fitted coilovers to the gf's dci, tried to refit the 182 cup wheels to it and they were fowling on the coilover and they wouldnt even sit flush on the hub. The same was for the standard wheel.
Am I in need of some spacers? I think 10mm is going to be needed. Where is best to get them, will I need longer bolts etc?
I had it on mine, it was out of line, had a play to shift the coilovers back a bit then had it re-aligned and it sorted the problem.
probably needs spacers. my inner tyre wall is about 2-5mm away from the adjusters on my clio needs spacers if i go any lower. so as a temp you could see if its that if so raise it up enough so that the adjusters dont get in the way.
