i'd check with someone good with electronics but i'm sure you could just wire a diode between the relay coil supply of the main beam relay and the coil of the dipped beam relay coil
my fairly small knowledge says this should work but you'll have to check with someone who knows
What car is it? I suspect its to do with your UCH output. It will send a live feed to the dipped and then, when you flick to main, will drop it and send a seperate feed to the main which is why you're losing the dip beam.
