Car Not starting
  A3 1.8T
Have a problem with my Mk2 Ph1 1.4.
Can't get it to start, can't be the starter motor as can hear it turning. Really dont know where to start looking for the problem?
  Ultra Red Clio 197
Ive had this problem twice now, though I hope it is fixed once and for all now..
Have you checked the battery? turn the key as if you are starting it. turn it two notches and watch the dash lights. they should all go out, except the handbrake light.. if the battery shaped one stays lit then thats the fault!
My battery was dead.. original hadnet been changed since it was made so AA man put a new one in and it started first time!
Good luck!. ;)
As said check the battery. Is the engine getting fuel? Is the imobilier warning light going off has the car got enough fuel (amazing how often people don't have fuel in them).
  A3 1.8T
All lights go off, battery seems fine.
I have just got it started but has happened couple of times. It is like the engine isnt getting fuel, if i trun key and keep the starter motor going it sometimes eventually kicks in but it is picking up slowly like it has only just got fuel. is hard to explain.
  A3 1.8T
Ok, is it something you are able to look/check yourslef or take to a garage job? Typicaly has happened day before new job interviews :(
If you have a multimter yes
220ohms the sensor should read but if it is broken then since you cannot get one for a bit its not that usful for tomorrow.
Its the sensor ontop of the gearbox next to the engine do a search for a picture.
