car pulling me all over the road and knocking
Car  Fiesta RS Turbo
Ph1 sport seems light on steering at 60, and it pulls me left and right depending on rd surface, and also a knock when i go around corners.. Is this the strut knocking or cv joint knackered??
track rod end or inner track rod most likly easy to check get the car jacked up and have a look for play in them
Cheeck top mounts and ball jnoint and track road inner and outers will be one of them unless the racks buggered (happens)
Same issue I'm having I'm sure!! Steering is mega heavy to the right but so light to the left. Will need to get it into a garage a suppose!!
yeah.. mine does that.. on a straight can feel the car snatching to the right which makes steering feel heavy but yet its light to the left.. are track rods the same from 1.2 upwards? as i might order all 4
I had the knocking noise. Changed thw lower ball joints. 1 had massive amount of play in it (previous owner had only changed 1 side). Drives lovely now.
knocking noise could be loose top mounts, i had it when fitted coilovas, tightened top mounts when fitted em but after bit of driving and they got settled in they started knockin so tightened top mounts and solved it, knockin could also be broken anti roll bar link seem to remember that mine knocked when it broke
