Car Stereo not powering up! Fuse blown! Air Con no display!
  Renaultsport Clio 17
2 fuses power your Clio car stereo - I was changing the wiring for a head unit that came in a Clio 172 that I had recently purchased. I identified the problem being the Amp was plugged into the wrong output. So, I connected it to the correct output, and then realised the head unit had no power. obvious solution - checked the stereo fuse (fine). Checked the fuse box stereo fuse (fine).. I scoured the net for clues and diagrams for relays etc.. Found nothing. 24hrs later I put fresh eyes on the fusebox and identified that a 20amp fuse with a picture of a side view mirror with arrows was the culprit. This little bugger power the Air con control panel and the clock. Sorted. I hope someone else finds this info quicker than I did.
