Car wandering, steering wheel shake
Dicky Belly 3
I'm still having troubles with my car :(
So far I have,
Replaced rear discs with new bearings
New brakes all around even
New inner tracks and track rod ends
Four-wheel Hunter alignment
Swapped tyres over front to rear
And I'm getting a steering wheel shake from 40mph onwards and when at around 50mph going around corners it's pulling my left and right and just doesn't inspire confidence. It's really quite scary at times as I don't feel in control.
I've checked the steering rack bushes and the thing isn't moving what so ever.
Checked the mount under the battery and that hasn't snapped etc, one at the other side is fairly new too.
Pulling my hair out as I'm spending money on fuel going to work etc but not fully enjoying the car what So ever :(
I don't think it's the balancing of the tyres as surely that wouldn't take effect until 60mph not 40mph? And that wouldn't cause this pull left and right?
Thanks, Daniel
Simon_16v
I'd say wheels need balancing. There's no predetermined speed at when the steering will wobble, it depends how untrue the tyre is.
As for the pulling to the side I'm not sure, did you get a print out from your alignment? Normally pulling to one side when braking is a sticking brake caliper.
Simon_16v
Also from looking at your recent brake replacement, did you grease the caliper pins that allow it to move side to side?
Dicky Belly 3
Thanks for the replies guys :)
Going to regrease the calipers today although I did them fairly recently when I painted them. Can bushes in the wishbone just fail randomly rather than wearing?
Dicky Belly 3
I'll have a look to see if they've come off
I've just realised I stupidly haven't actually changed the wishbone ball joints!! I didn't realise there were two ball joints.
Could this lead to the sloppiness. Just removed one and it feels fairly slack. Not ridiculous but not nice and stiff??
Simon_16v
Well jack the car up, hold one front wheel at the top and bottom and give it a wiggle. If there's any movement then ball joint is goosed, if there isn't then they should be fine.
But when you grease the pins up the caliper should move freely from side to side.
Dicky Belly 3
I've ordered some anyway.
I'm starting to think the wandering could be from a worn dogbone mount?
I also get a clunk now and again when changing gear, sometimes it really struggles to go into gear and maybe that's what could explain why the car is all over the place when braking if it's not supported at the dogbone mount.
Ordered a powerflex one anyway!
Darren S
Your alloys may need balancing?
Yep - fixed my steering wheel shake issue at 50mph+
Best bet (if you can manage it) is to get the wheels off and wash the inside of the front alloys (or all of them, if you you've moved front to back previously) - with some warm water and washing up liquid. Fairy is brilliant at getting the CV grease off the inside of the front alloys and will give you much more accurate grounds for balancing the wheels afterwards.
D.
  Mazda3 2.2D 185BHP
D.
That dirt can add some weight!
Plus the weights will stick to the alloy far better if its clean and degreased
Dicky Belly 3
I did that at the weekend as the rears had loads and to be honest I think it's decreased the shake! Going to get them balanced properly.
Do my symptoms sound like a dogbone issue also do you guys reckon?
  Mazda3 2.2D 185BHP
What sort of shake is it now?
I had some shake after getting new wheels which has now gone when i went from a Powerflex Dogbone to a New OEM one. Much better.
Oh and the judder i used to have from pulling away in 1st is virtually gone with the OEM dogbone
Simon_16v
Dog bone mount won't cause wandering.
If you come through to Selby one evening I'll have a look at it. I'm by no means a mechanic but have some experience.
Dicky Belly 3
Any change since you replace the ball joints?
Honestly mate, I think it's fixed it!! I'm still getting a slight juddering probably due to the wheels need balancing butttt it's not pulling when accelerating and braking anymore and I only got a little chance to have some fun and it doesn't seem to be pulling me around anymore! Going to get the wheels balanced now and report back
Simon_16v
To be honest I'd get your wheels balanced and also have the tracking checked as the new ball joints may have put it out slightly and you don't want to wreck your tyres!
Dicky Belly 3
Haha funny you say that, got it all booked in for a realignment on Friday and the tyres balanced! He's only charging me £15 too for the alignment which is ideal
