carbon lorraine dot 4 brake fluid, how much do i put in for full change?
  Clio 182
i am doing full fluid change and got 3 x 500ml of carbon lorraine dot 4 fluid and not sure how much to put in :S how much do i use? cheers, Jamie
  ITB'd MK1
pump it through until the fluid is coming out clean from each bleed nipple (keep the reservoir topped up). Normally takes about half a litre
