Is this on road or track
Do you have brake ducts
Do you have arch liners
Have you got a heatshield between manifold and cylinder
Are you using the brakes too much
All these need to be answered,or does it just boil stood on your drive?
Castrol super response is good stuff,and being Dot4 is less likely to absorb moisture.Dot 5 stuff will,but will be fine if changed and bled on a regular basis.
Just pull it all out, mines all gone, along with the fogs!
I've done the same.
Yes, everything
