Car's Doing My Head Innnnnn
Car  Mk3 Clio
MK3 clio
i hit a kerb going round a right corner at about 40mph and damaged alot of things
i have replaced so far :
strut
lower arm
drive shaft
drop link
and it is still not sitting right the wheel is pushing out the way at the top and pushing in the way at the bottom of the wheel
enyone got eny ideas or have been in this mess before ???
Positive camber. Was the lower arm defiantly replaced? Has the subframe been checked? Or it could be possible hub/bearing/strut damage.
2 morro morning i will check the lower arm is the correct one and size..
but i fear that the subframe could be kinked or damaged how much u reckon this should cost ?
Depends how much you can source a second hand subframe for mate! Fitting is a bit of a ballache, but quite straight forward.
Sub frame for a Mk3. I'm guessing a lot around 100 - 200 ??
but cant be sure. I'm not sure if Josh (Cliospares) is breaking Mk3's yet but try him out.
When you hit the curb did you have your wheels turned? When I did a similar thing at a similar speed through skidding on black ice I needed a new steering rack.
my wheel was full lock to the right and bounced of the kerb at a force
there was no steering rack damage i was just having a think in the bath there and i think the hub could be bent because if a hit the kerb at that force and knocked the bottom of the wheel in the way quite possible
i have allready spent £350 on renault parts (discount)
absolute killer all my fault thoo
