Ph1 Clio 172
Not sure if i've put this in the right place, but hopefully i have!
Basically, central locking doesn't work using the key fob or putting the key in the door. When you press the button on the fob a small red light flashes on the fob, but nothing happens. The car does lock everything using the button inside the car and locks when you reach 10mph.
I've followed the guide on here for programming a key as i thought it may be that, but it did nothing. Just looking for a bit of guidance now.
If it matters, its a ph1 172
CHEERS!
CHEERS!
