Centre cap issue.
Car  Italian 3.2 V6
I have speedline turinis (16" - et40 offset) but they have the speedlines centre caps. I need Renault ones.
What's the deal with it as iv herd that Renault ones don't fit bit them again iv seen and herd of people doing it?
Please help!
Which ones Do I need? Renault ones or custom made ones from else were?
Cheers, PSJ.
If it helps I can tell you that the Renault caps are 58mm accross. Can you not fit customised Renault badges to the current centre caps?
Cheers dude, I'll measure the speedline dia when I get home.
And yea that's prob the best idea if Ren ones won't fit as I'd rather get the proper ren ones tbh.
Cheers, PSJ.
If you decide to buy the renault one's i'll buy the speedline ones off you.
I've found them for £30 for 4, Seems a bit steep.
the renault caps wont fit the speedlines as the speedline ones are completely different to the renault speedlines
the renault ones have more of a concave also
speedline ones sit narrower aswell.... gay:dapprove:
Oh, gay!
So my only option it too custom make a set!
If so I guess I'd have to buy some Renault ones anyway just to steel the badges off to fit to speedline centre caps :S :(
PSJ.
No chance you can compare your centre cap to someone with Renault turinis to see if the badge fits? If it does it's a simple case of spray the center cap, cut the clips off the badge and glue it on et voila.
Have the urge for some silver Turinis on my iceberg again :o
tbh psj i would try and find some trophy/cup oem renault speedlines, if you find a pic on here look at the center and then look at the center on your wheels you will see what i mean, the clio ones have a more dished wheel center where the wheel bolts go in
