Change in MPG - RSTuner and Induction Kit
  BG 182
So since I got the 182 in Febuary this year in have averaged 32/34 mpg. Two weeks ago I fitted a pipercross viper carbon and put the Ron 98 map on the car and MPG has dropped to 27/28 is this normal?
  2010 Jetta TDi 140
Yes, mine did the same. It's because you put your foot down more for the induction noise!
  C1 VTR (Company Car)
Induction kit = More air = More petrol burned.
Map = Higher revs = More petrol burned.
  AB182, Audi A5 3.0
If your doing short trips, the MPG will go up in winter months quite a bit as the cold map effectively stays on for longer thus you burn more fuel in the cold map. Take it for a 20mins+ run, then when hot, reset the MPG. this will give you a better idea of what its doing once the engine is hot and its not running the cold map.
