changed front pads, now abs traction control and service light come on occasionally?
Hi, changed my pads the other day on my 182, done it before so all should have been ok, it all went well, but occasionally now the abs, traction control and service light come on, it then goes after i turn off the engine and turn it back on again, it doesnt do it all the time or for any particular reason that i can see, i had this problem before with the sensor and got it replaced by renault has been fine untill i changed the pads, i just wanted to know if anyone has had the same problem or can shed any light, or is it just whilst the pads are wearing in? thanks.
  ph2 172
Re: changed front pads, now abs traction control and service light come on occasional
it will be the sensor it will prob need adjusting see guides section
Da
  Less
Brake pedal switch probably needs adjusting.
Hi, im still having this problem even after ajusting the sensor, it is better now and only comes on some times maninly in traffic, is ther a certain nack to ajusting it? or could it be somethin else? thanks.
  megane 225
have you tried a new sensor, i adjusted mine which then caused the lights to come on, replaced the sensor and everything was fine
cost me about £8
