changed gearbox, wont start, bad smell
Car  330Ci Clubsport
think Ive blown the starter motor. car primes up ok but when I try to start I get a noise like when the battery is dying, lights dim but doesnt turn over. after a few goes I checked under the bonnet and there was a nasty electrical smell and the starter seemed to be humming.
any thoughts?
cheers.
2 earth straps on ok. I've a horrible feeling the flywheel is jammed or something which would make me kill myself at the thought of having to take the box out again.
I did have this connector "left over" if that makes a difference
Next plan is to remove the starter, and check if the flywheel can be turned by hand. If it cant Ive f**ked up the box fitting and jammed the flywheel tight :(
