Changed HT leads but revving to limit.......
Car  Clio 182 Trophy. No. 189
.................any ideas?
After I fitted new leads the car revs straight to the limiter?!
Have i fitted them incorrectly or something?!
1 is gearbox side, 4 is cambelt side, but that would result in misfiring, not hitting the limiter :p
put it this way if they were in the wrong order it would either misfire or pop and bang
go back to the start and retrace what has been done - as it was not doing it before
as said sounds like its got an air leak causing the revving up
Did you renew the rubber seal - it's recommended that it's replaced when you take off the plenum.
Mine did this though after I replaced the ICV - idle control valve. Sorted it eventually by adjusting the ICV.
it will be the plenum chap, you will have an air leak somewhere, if its revving like hell every time you switch it on you wont be able to tell, take the plenum back off and put it bk on chap
