Changing disc’s
Car  1.6 focus zetec....
Whats the best way to push the caliper back when changing the discs on a williams?
i havent got a clamp or anyhting and thought id read on here that you could disconnect the brake fluid pipe to do it?
Just use the flat side of a spanner across the piston and push on either end, no need to disconnect anything otherwise youre just making yourself work!
Quote: Originally posted by BRUN on 07 August 2005
do you have to take the cap off the brake fluid reservoir when doing this ?
Yep.
You can do it with your hands if your not a wimp (I use a G clamp)
