thanks, not too bad then. Is £50 for a used driveshaft a good price?
I think my cv joint has had it.
Why do you think that? you sure a new gaitor and a repack wouldnt do?
Been offered a driveshaft for £50 for drivers side, is it easy to fit?
Yes, check the guides, otherwise i have pic by pic here to help you
Any special tools needed?
Not really, 30mm socket for the axel nut + a long breaker bar (take to a garage to undo WTF! then what? who ever said^) BJ Splitters are s**t also, use a rubber mallet if its stuck or just press the track rod out with your hand..
or undo the 2 17mm nuts on the Bottom ball joint and do it like that.
CV joint will only knock when its turning.
