Changing gearbox oil
Car  Renault Clio RSi Mk1
I am going to be changing my g/b oil next week and was wondering if the drain plug is the same as the engine oil one ?
Had to drop the car back down and bugger off to Halfrauds when i changed the engine oil as i didnt have the correct tool to undo the sump plug :o
Just want to avoid this again..
Cheers Keith
Gearbox one on the valver as a hex on it as well incase you don't have the square tool so could use either?
As sami said on all the Mk1's I've worked on, as far as I know the plug on the gearbox can be undone using the same bit as the engine sump plug, or using a 13mm (iirc) socket.
