Changing the Tweeters???
Car  Clio dynamique 1.4 16v
I've read on the ozrenault forum that people have managed to change the dash tweeters without removing the dash. Has anybody here managed it cos when i removed the grill you would need hobbits hands to get it out. Any ideas?
you need to unscrew them with you hands. They are on tight though. I took the dash off because it was easier. Takes 10 mins.
I think you need to find a Hobbit then.
I don't think the tweeters and the grilles even line up exactly, they are offset slightly to direct the sound.
Take the dash out, its only 7 screws, easy job, then you can work without hindrance. ;)
I thought there were about 14 screws? Also renaults are bad another for creaks without me helping it.
I recently changed components to MB Quart - the best way is to remove the dash as tweeter connections were difficult to remove by way of the hole in the dash. I spliced the crossover into the front speaker wires and mounted under the glovebox, running new wires direct to the new tweeters. Woofers used existing Renault loom. Fiddly but not difficult job - locating the right speaker cables typical Renaut
